2018-01-24 12:38 AM
Any one know what is USB TID? And, have some one know how to get the ST USB TID number?
2018-01-24 03:13 AM
First hit simply googling 'USB TID':
http://www.usb.org/developers/compliance/cable/
Note:
T
estID
s (TID
s) are assigned by the USB-IF or by the certified independent test lab at the time of testing.2018-01-24 05:39 PM
Dear Clive:
Thanks for your quickly reply.
Is this TID same to STM32F429IIT6 TID? or Could you please give me some suggestions?
2018-01-24 05:41 PM
Thanks for Neil. I got it. However, I also didn't know what is ST TID number.
2018-01-24 05:51 PM
Try the datasheet
2018-01-24 06:58 PM
Thanks for you. I got it.
2018-01-24 06:58 PM
I don't think you can use a TID to side step the USB certification of your own product.
In the case of USB-C part of the certification is presumably you have a compliant driver.
2018-01-31 07:00 AM
Hello
Wu.Jyunwei
, As mentioned byNeil.Andrew
, Test IDs (TIDs) are assigned by the USB-IF or by the certified independent test lab at the time of testing. In order to get the TID number of a certified USB , you have to visit the . Below, you find an example of the STM32F072(LS/FS):Khouloud.
2018-01-31 07:38 PM
Dear
Khouloud,
thanks for you, I got it.
