USB TID?
JYUNWEI wu
Posted on January 24, 2018 at 09:38
Any one know what is USB TID? And, have some one know how to get the ST USB TID number?
8 REPLIES 8
Andrew Neil
Evangelist III
Posted on January 24, 2018 at 12:13
First hit simply googling 'USB TID':
http://www.usb.org/developers/compliance/cable/
Note:
T
est
ID
s (
TID
s) are assigned by the USB-IF or by the certified independent test lab at the time of testing.
JYUNWEI wu
Posted on January 25, 2018 at 02:39
Dear Clive:
            Thanks for your quickly reply.
            Is this TID same to STM32F429IIT6 TID? or Could you please give me some suggestions?
Posted on January 25, 2018 at 01:41
Thanks for Neil. I got it. However, I also didn't know what is ST TID number.
Posted on January 25, 2018 at 01:51
Try the datasheet
http://www.st.com/content/ccc/resource/technical/document/datasheet/group3/65/5e/1a/16/7d/f4/44/97/DM00227288/files/DM00227288.pdf/jcr:content/translations/en.DM00227288.pdf
JYUNWEI wu
Posted on January 25, 2018 at 03:58
Thanks for you. I got it.
Posted on January 25, 2018 at 02:58
I don't think you can use a TID to side step the USB certification of your own product.
In the case of USB-C part of the certification is presumably you have a compliant driver.
Khouloud GARSI
Lead II
Posted on January 31, 2018 at 16:00
Hello
Wu.Jyunwei
As mentioned by
Neil.Andrew
, Test IDs (TIDs) are assigned by the USB-IF or by the certified independent test lab at the time of testing.
In order to get the TID number of a certified USB , you have to visit the
http://www.usb.org/kcompliance/view/catalog_search/sselect_item/process/refresh?profile=b53bcd5efdcd514ee2b6df3a16feb10f5294b275&referring_url=http%3A//www.usb.org/channel&keywords=STM32&step%3Aint=2&tab_data_namespace=28681966A78ZIB4vgcw&sitemlist_batch_start%3Aint=1
Below, you find an example of the STM32F072(LS/FS):
Khouloud.
Posted on February 01, 2018 at 03:38
Dear
Khouloud,
            thanks for you, I got it.
