USB Host mode Configuration in stm32h503rbt6 controller
Mohan30
@hi all,
I newly working in USB Host mode configuration in stm32h503rbt6 controller using Keil software(without Hall code),
this isn't very easy for me, I can't understand, how to use this method.
actually, this implementation is to communicate (stm32 (Host)) with Tablet(device).
I spent one week to USB understand this concept but couldn't, so please can you suggest me and share some notes for achieve this configuration
Thanks,
FBL
You are welcome @Mohan30
If you need example for device STM32CubeH5/Projects/NUCLEO-H503RB/Applications/USBX/Ux_Device_CDC_ACM at main · STMicroelectronics/STM32CubeH5 (github.com)
For host mode, I can share with you this example
I'm out of offce with limited access to my emails.
Happy New Year!
4 REPLIES 4
FBL
Hi @Mohan30
Which board are you using? I suggest you following the workshop on H5 STM32H5 workshop - 09 USB - USBX-CDC lab (experts) (youtube.com) If using Nucleo-H503, USB Host configuration is not recommended because it is not USB-C® compliant.
However, if you would you like to use it for testing purposes you should set the following solder bridges :
  •  SB1 and SB7 ON
  • SB14 ON
  • SB4 and SB8 OFF
Happy New Year!
Mohan30
@FBL  Thanks, dude.
I searched a lot on Google, but I can't get the correct code, can you suggest a sample working code for the USB Device?
I try to implement it but this isn't very clear to me.
FBL
Happy New Year!
Mohan30
@FBL  Thanks for helping me dude.
