Undefined reference to HAL_UART_Init
‎2019-02-07 2:22 AM
Anyone knows how to fix undefined reference to HAL_UART_Init,HAL_UART_receive
I included all necessary files for this but somehow it doesn't find any reference
#include "stm32f4xx_hal.h"
#include "stm32f4xx_hal_conf.h"
#include "usb_device.h"
#include "usbd_comp_if.h"
#include "usbd_comp.h"
#include "stm32f4xx_hal_usart.h"
#include "stm32f4xx_hal_uart.h"
#include <stm32f4xx_hal_uart.c>
#include "main.h"
#include <stm32f4xx_hal.h>
#include <stm32_hal_legacy.h>
extern HAL_StatusTypeDef HAL_UART_Init(UART_HandleTypeDef *huart);
‎2019-02-07 3:00 AM
A common convention in C coding is to NEVER EVER # include *.c files, i.e. sources.
Apart from that, check where the missing function is implemented, and if the regarding source file is built with the project. In this case, supposedly stm32f4xx_hal_uart.c.
Including said source file would effectively create a second implementation, resulting in duplicate linker symbols.
You don't use C++, do you ?
‎2019-02-07 3:18 AM
Including the C file is probably a desperate attempt to get the function defined :)
The unresolved reference likely occurs because HAL_UART_MODULE_ENABLED not defined:
This normally should be defined in your stm32f4xx_hal_conf.h.
It is created and updated by CubeMX. If you added the UART outside of the Cube, add also #define HAL_UART_MODULE_ENABLED in the .h
-- pa
‎2019-02-07 3:25 AM
no i use c
i removed the double implementation it still throws an error
‎2019-02-07 3:26 AM
Hi :beaming_face_with_smiling_eyes:
I defined it thanks for the hint but it still isn't defined
‎2019-02-07 3:55 AM
Look from where comes the error - compiler or linker. Undefined reference is a linker error and means that compiled function can't be found in object files. In this case it means that stm32f4xx_hal_uart.c is not compiled and linked.
‎2019-02-07 4:12 AM
Post the exact error message from your toolchain, not just short excerpts.
And don't forget preceeding errors, if any.
As a general rule, always start fixing with the first compiler error. Small syntactical errors can cause a torrent of aftereffects.
Do a file search in *.c files for the HAL_UART_Init label.
One of the files should supposedly be part of your project.
If so, check for surrounding # if / # ifdef labels, that possible keep your compiler from seeing it.
Know your tools.
‎2019-02-07 6:24 AM
ST does this differently, you include one top level include file, and it then pulls the stm32f4xx_hal_conf.h where you've marked the specific modules you want to include. And then you add the .C files from the library into the project.
‎2019-02-07 6:26 AM
thanks I fixed it that way.
Now i got my composite device working any idea why i can't connect to USB Serial Device COM Port?
‎2019-02-07 6:26 AM
