unable to flash NUCLEO-H7A3ZI-Q
Chandramouli
Hi Team,
we are facing issue with flashing NUCLEO-H7A3ZI-Q board.
is any problem if we flash stm32h7a3zit6 code on stm32h7a3zit6q.
can we give a suggestion ASAP
5 REPLIES 5
FBL
Hi @Chandramouli
STM32h7a3zit6q embeds SMPS power supply. So check in your code if SMPS is configured you can flash your code without issues
I'm out of offce with limited access to my emails.
Happy New Year!
SofLit
we are facing issue with flashing NUCLEO-H7A3ZI-Q board.You need to provide
 You need to provide a details for that. Error message, or screen shots ..
Thanks for quick response,
we did flash stm32h7a3zit6 code on stm32h7a3zit6q. then onwards NUCLEO-H7A3ZI-Q board not working,
compiler showing below message,
Target no device found
Error in initializing ST-LINK device.
Reason: No device found on target.
As stated by @FBL, what is the power configuration you set in your FW? LDO or SMPS?
FBL
I would suggest you connect to the target using CubeProg in Power Down mode and erase the flash.
Happy New Year!
