unable to flash NUCLEO-H7A3ZI-Q
‎2024-05-09 12:48 AM
Hi Team,
we are facing issue with flashing NUCLEO-H7A3ZI-Q board.
is any problem if we flash stm32h7a3zit6 code on stm32h7a3zit6q.
can we give a suggestion ASAP
STM32H7 Series
‎2024-05-09 02:38 AM - edited ‎2024-05-09 02:39 AM
STM32h7a3zit6q embeds SMPS power supply. So check in your code if SMPS is configured you can flash your code without issues
‎2024-05-09 02:43 AM
we are facing issue with flashing NUCLEO-H7A3ZI-Q board.You need to provide
You need to provide a details for that. Error message, or screen shots ..
Thanks for quick response,
we did flash stm32h7a3zit6 code on stm32h7a3zit6q. then onwards NUCLEO-H7A3ZI-Q board not working,
compiler showing below message,
Target no device found
Error in initializing ST-LINK device.
Reason: No device found on target.
‎2024-05-09 03:21 AM
As stated by @FBL, what is the power configuration you set in your FW? LDO or SMPS?
‎2024-05-09 06:16 AM
I would suggest you connect to the target using CubeProg in Power Down mode and erase the flash.
