2025-02-24 4:19 PM
I am working with a NUCLEO-STM32H7S3L8 board, but I am unable to connect to it using STM32CubeProgrammer or flash firmware using STM32CubeIDE. However, I am still able to update the board’s firmware successfully.
I suspect that I might have pressed the reset button while flashing firmware to the device, which could have caused the issue.
What steps can I take to recover my board and regain access?
Any help or suggestions would be greatly appreciated.
Thank you!!
2025-02-24 11:45 PM
Hello @AlexShao and welcome to the community,
Which error did you get?
Could you please
I hope this help you!
Please let me know if the issue is solved or not?
Thank you.
Kaouthar
2025-02-24 11:45 PM
Could you please
Thank you.
Kaouthar
2025-02-25 11:26 AM - edited 2025-02-25 11:27 AM
Dearest Kaouthar,
The solution you shared solved the problem. The board is functional again.
I was getting the error "Error: No STM32 target found! If your product embeds Debug Authentication, please perform a discovery using Debug Authentication."
Thank you so much!!
Alex
