2015-11-08 5:03 PM
Regarding
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00039084.pdf
- the user manual for the Discovery kit for STM32F407/417 lines: On page 20, in section 4.11 ''Solder bridges'', SB19 (BOOT1) has a listed default of OFF (held high). However, on my Discovery board the jumper is present (ON), and therefore the BOOT1 line is held low. I believe this is a mistake in UM1472, as the Discovery board performs as expected. #stm32f42015-11-09 6:10 AM
Hi johnson.seth,
Thanks for highlighting this typo in the user manual, The default state is ''SB19 ON''. It is reported internally to be fixed in coming version. -Syrine –
