UART transmitter transmits wrong ascii value to my pc.
‎2023-09-22 10:18 PM
what is the problem in my code..??
I put a charecter in Data Register, but serial terminal show another ascii code.
My IDE is KeiluVision5. the code is in below.....
- Labels:
Documentation
STM32F4 Series
UART-USART
‎2023-09-22 10:39 PM
The most common reasons are a baudrate mismatch between transmitter and receiver or some different code page/char translation done by "intelligent" terminal progs on the receiver side. Check the signals on the wire using a scope or a cheap logic analyzer.
hth
KnarfB
hth
KnarfB
‎2024-03-19 09:28 AM
Thank you for your suggestion.
