Uart timeout?
vitthal muddapur
I am using LPUART for sending data to the GSM. I wrote own uart transmit driver without timeout, like
void LPUART1_Send_Data(uint8_t *string)
while(*string)
if((LPUART1->ISR & USART_ISR_TC)==USART_ISR_TC)
LPUART1->TDR=*string;
string++;
any possibility to getting issue without timeout ?
3 REPLIES 3
> Any possibility to getting issue without timeout ?
Transmit only?
No, unless you decide to shoot yourself into your foot (by doing something completely nonsensical, e.g. switching off the LPUART's clock in an interrupt).
Don't use TC, use TXE
Thank you
This Function handler Okay ?
any possibility to hanging here ?
while(*string!='\0')
if((LPUART1->ISR & USART_ISR_TXE)==USART_ISR_TXE)
string++;
