UART TIME OUT
‎2023-11-30 3:22 AM
Hello everyone
I am trying to receive file form UART through Xmodem protocol I am getting file in debug mode but unable to get into run mode it showing UART Rx busy basically hanging over these function
while (!(HAL_UART_GetState(&huart4) == HAL_UART_STATE_READY) && wTimeout) {
wTimeout--;
if (HAL_UART_GetState(&huart4) == HAL_UART_STATE_READY)
break;
Can anyone suggest me for the what's wrong with the code
STM32L4 Series
UART-USART
‎2023-11-30 4:41 AM
Hello @PESHWA
Could you specify the product being used, please?
‎2023-11-30 4:45 AM
The host isn't sending data?
You've got some stuck error status like noise, framing, parity, overrun that you need to clear before reception works?
‎2023-11-30 4:49 AM
The timeout also isn't time bound it's iteration bound and this can change depending on execution speed and optimization. You need it to run in consistent time.
‎2023-11-30 7:52 PM - edited ‎2023-11-30 7:59 PM
yes STM32L4 MCU and with help of tera term as serial terminal as any idea why this happening
NOTE : I am using IAR workbench as IDE
‎2023-11-30 7:56 PM
Hi
I am doing in consistent time frame
/* USER CODE END UART4_Init 1 */
huart4.Instance = UART4;
huart4.Init.BaudRate = 19200;
huart4.Init.WordLength = UART_WORDLENGTH_8B;
huart4.Init.StopBits = UART_STOPBITS_1;
huart4.Init.Parity = UART_PARITY_NONE;
huart4.Init.Mode = UART_MODE_TX_RX;
huart4.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart4.Init.OverSampling = UART_OVERSAMPLING_16;
huart4.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE;
huart4.Init.ClockPrescaler = UART_PRESCALER_DIV1;
huart4.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
if (HAL_UART_Init(&huart4) != HAL_OK)
Error_Handler();
if (HAL_UARTEx_SetTxFifoThreshold(&huart4, UART_TXFIFO_THRESHOLD_1_8) != HAL_OK)
Error_Handler();
if (HAL_UARTEx_SetRxFifoThreshold(&huart4, UART_RXFIFO_THRESHOLD_1_8) != HAL_OK)
Error_Handler();
if (HAL_UARTEx_DisableFifoMode(&huart4) != HAL_OK)
Error_Handler();
here are my uart configuration and Iam using uart interrupt for communicate
‎2023-11-30 7:57 PM
HI Host is sending char(C) as per showing on serial terminal
