UART RX Busy Flag Constantly Set
‎2023-04-06 1:27 PM
I had a project I was using on the L053 Discovery Board (STM32L053C8T6 micro) that was receiving some data from the UART that was working fine. Built my own board using a different L0 part (STM32L010F4P6). When I try to run this same project, the UART comes back as always busy receiving, even with no data present (RxState == HAL_UART_STATE_BUSY_RX).
I'm using the latest version of the L0 Cube HAL. I see in the past some people were manually clearing the flag using the HAL_UART_RxCpltCallback, but the current versions of the HAL specifically advise against modifying this.
But I don't see where the RXState actually gets set to "Ready". Am I missing something? Do I need to manually service the flags?
STM32L0 Series
UART-USART
‎2023-04-07 3:55 AM
Hello @Community member​ ,
I recommend you to follow properly the steps as described in this wiki page: STM32StepByStep:Step3 Introduction to the UART - stm32mcu
Also, If your project is based on a generation of code with STM32CubeMX, this article can help you to migrate your current STM32L053C8T6 example to the STM32L010F4P6.
I hope this help you to solve the issue!
Thank you for your contribution in STCommunity.
Kaouthar
‎2023-04-08 7:35 AM
Found the issue. Can't delete post.
‎2023-04-08 9:55 AM
The value of a forum is that its a collection of questions and answers.​
