2012-04-17 2:18 AM
If I try to configure the TS module on a STM32L151 all TS pin will appear green and blocked for other use. I like to configure only 4 pins for touch. This seems to be not possible with this tool or is there a trick?
Raig #stm32l-touch-microxplore2012-04-25 12:20 PM
I confirm you that the tool MicroXplorer is not suitable to check a configuration involving some touch sensing pins. Selecting the TS function automatically enables all the TS pins. This behavior is not correct and the tool will be updated to offer more flexibility. Best Regards, Thierry,
