Toolchains build around vim editor
BParh.1
Senior III
I personally like Vim as an editor. But it lacks of toolchains support for embedded development especially on Windows operating system. May I know if someone manage to find the right recipe?
  1. How do you get compiler ?
  2. How do you get the debugger?
  3. How do you get the code intellisense for C/C++ ?
2 REPLIES 2
Looks like you can get VIM plugins for Eclipse.
https://marketplace.eclipse.org/content/vrapper-vim
I doubt anyone is going to invest in making an entire IDE for such a small audience.
BParh.1
Senior III
Thanks @TDK​ , but the reason I prefer Vim is to avoid IDE like eclipse which in my personal view is too heavy weight.
I am thinking to do the development process via command line. So in CubeMX I can choose to generate the project as Makefile. But then I need to find out how to build, debug via command line. For Linux this is easier, but for windows, I am not so sure.
