Timer -> DMA -> SPI
‎2023-07-03 3:22 PM - edited ‎2023-07-04 9:31 AM
I am having trouble getting the Timer to trigger a DMA -> SPI operation. Namely, I want to set the timer up to run,. Then, get every overflow event to trigger the DMA to move a byte into the SPI. The SPI should auto-send. Then, the cycle repeats until the DMA has moved a N-bytes.
I am feeling really blind, because I cannot figure out the problem. At first, I was trying to find the right setting to get the Timer to trigger a DMA request upon UEV generation. However, I could not find such a feature. So instead, I setup DMA1 Channel 3. TIM6 should map to this DMA. Then I setup TIM6 to generate a UEV upon Overflow (URS = 1, UDIS = 0). Finally, I setup TIM6 to generate a DMA request upon update (UDE = 1).
Still nothing.
Can I get some input?
What I am trying to do may not be possible in the way that I thought.
Would the DMA rapid fire send N-bytes to the SPI upon the first successful DMA request? Is there a way to get it to send only 1 byte at a time, triggered by the timer?
And auto-increment through memory? So..
- Timer6 -> Overflow -> UEV -> DMA -> Byte 0 -> SPI
- Timer6 -> Overflow -> UEV -> DMA -> Byte 1 -> SPI
- Timer6 -> Overflow -> UEV -> DMA -> Byte 2 -> SPI
- Timer6 -> Overflow -> UEV -> DMA -> Byte N -> SPI
STM32L4 series
‎2023-07-04 2:46 AM
Hello @Dude, thank you for your post,
The problem could be related to the time trigger or the DMA config as well as the SPI peripheral!
So, first, make sure -by looking at the datasheet- that the DMA request is lined to the right SPI peripheral
Regarding your question about the DMA; ofc it is possible -in the DMA config- by setting the DMA transfer size to 1 byte and enabling auto-increment for the DMA source address.
Regarding the timer trigger, I think one way to know if the UEV is triggered is the use an interrupt handler for the timer's UEV and use a GPIO pin or print a message... to see if the UEV is even triggered! -Maybe it's not the easiest way but you need to localize exactly where comes the problem
Hope that helps!
‎2023-07-04 10:03 AM
‎2023-07-03 3:27 PM - edited ‎2023-07-04 9:31 AM
Content shuffled up
‎2023-07-03 3:28 PM - edited ‎2023-07-04 9:31 AM
Content shuffled up
‎2023-07-04 2:07 AM
Which STM32?
How do you trigger DMA? Show the register which selects the trigger source.
‎2023-07-04 2:46 AM
Hope that helps!
‎2023-07-04 8:28 AM - edited ‎2023-07-04 9:35 AM
Okay so the Timer is triggering an UEV event when I use interrupts.
‎2023-07-04 8:31 AM
So Channel 3 should be able to be triggered by TIM 6 and cause SPI1 TX to transmit...?
‎2023-07-04 8:33 AM - edited ‎2023-07-04 9:34 AM
Content shuffled down
‎2023-07-04 8:49 AM - edited ‎2023-07-04 9:34 AM
Content Shuffled down
‎2023-07-04 9:11 AM - edited ‎2023-07-04 9:36 AM
Are you sure that the transfers can do as I want? Thanks to you and Waclawek.jan, I am able to get the DMA to trigger, as caused by TIM6 UEV occurrence.
Will the DMA in circular buffer mode with N-bytes (CNDTR3 = N-bytes arbitrary number) move one byte per DMA request or N-bytes per DMA request?
thanks
