The LL drivers for F4
achin
Posted on March 03, 2017 at 14:03
The documentation here (
http://www.st.com/content/ccc/resource/technical/document/user_manual/2f/71/ba/b8/75/54/47/cf/DM00105879.pdf/files/DM00105879.pdf/jcr:content/translations/en.DM00105879.pdf
) states that the F4 should have LL drivers. When can we actually expect a release of this?
5 REPLIES 5
Imen.D
Posted on March 03, 2017 at 14:15
LL drivers support
for STM32F4 device will be available soon in the next release of STM32CubeF4 V1.15.0.
Imen
Imen
Imen.D
Posted on March 07, 2017 at 14:00
Hi chin.andrew,
https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef4.license%3d1488889419809.html
is now available with support of LL drivers.
Hope this bring you some help.
Imen
Imen
achin
Posted on March 09, 2017 at 20:22
I installed this. When I go to ''settings'' it does not allow me to select LL drivers. 0690X00000606X0QAI.png
Posted on March 13, 2017 at 17:14
Hi chin.andrew,
The support of LL drivers is available for STM32CubeF4 firmware package but not yet supported in CubeMx.
Imen
Imen
Posted on March 13, 2017 at 20:27
In '2017 STM32 Wish List'
vera.laurent
stated '
Low Layer will be basically the replacement for SPL.' I downloaded STM32CubeMX Version 4.0 and I only found the following LLsource files (and their associated headerfiles):
stm32f4xx_ll_fmc.c
stm32f4xx_ll_fsmc.c
stm32f4xx_ll_sdmmc.c
stm32f4xx_ll_usb.c
Is that all there is? This hardly looks like a replacement for SPL. We have a lot of modules written in SPL and have been putting off moving to HAL since SPL and HAL are not compatible.
Edit: This was not intended as a nasty rhetorical question. We had hoped to use LL as a sort of easy transition to begin using HAL (especially since I was told by ST that they are thinking of making a conversion utility to convert SPL to LL). If this is all there is, we will obviously need to re-think that. An answer by ST would be much appreciated.
