The GPIO output before initialization
pass3master
Senior
We are developing a device using the STM32H743.
We are setting up the GPIO during initialization, but I am wondering about something.
What is the GPIO output before initialization? Is it high impedance?
Or does it change depending on the circuit connected to the STM32H743?
Sorry I didn't understand your last question.
After reset it's set to Analog input and it's in high impedance state (from RM0433):
PS: This is NOT an online support (https://ols.st.com) but a collaborative space. So please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help/support.
5 REPLIES 5
SofLit
After reset it's analog input:
After reset the output is normally set to 0:
If you need to set it at a specific value on the initialization stage, set the value of the pin on ODR or BSRR register then configure the GPIO as output.
Thank you for your answer. I see, analog input!
Is it floating as an electric potential?
And if you need a specific pin state during reset and before initialization, you need an external PULL resistor.
Thank you for your reply.
I understand the specifications now, so I will close this.
