stm3f373 clock and flash latency setting
Options
‎2016-03-04 12:19 AM
Posted on March 04, 2016 at 09:19 I worked with stm32f373. To reduce power consumption I change the Hclk to 24Mhz and 48Mhz System clock. (use AHB prescaler to /2) But I confused by flash setting. reference manual said that the latency is 000: Zero wait state, if 0 < SYSCLK? 24 MHz 001: One wait state, if 24 MHz < SYSCLK ? 48 MHz 010: Two wait sates, if 48 < SYSCLK ? 72 MHz but the st library source code said that the latency is choosed by Hclk not system clock what is correct? and what should I consider when the sys clk different with Hclk ? #stm32
Options
‎2016-03-04 6:21 AM
Posted on March 04, 2016 at 15:21
Hi choi.gazam,
The number of wait states depends on HCLK range.The description should be reviewed in the reference manual. Thanks for highlighting this.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
1 REPLY 1
Options
‎2016-03-04 6:21 AM
Hi choi.gazam,
