STM32L562CET6 won't enter EXTI callback function.
‎2021-10-11 4:42 AM
I am quiet new to STM32 programming and can't get the external interrupt to work.
I started with the NUCLEO-L011K4 and wrote my programm without any issues. I switched to my own board (pdf included) and weren't able to get extrenal interrupts to work.
I use the STM32CubeIDE 1.5.1 and the ST-Link/V2 to programm.
The goal of the code is to change the PWM outputs frequency and duty cycle with incoming 5V high signals on pin "Change" and pin "Laser_On". The Controller itself gets 3,3V.
I can see in debug mode that the Callback function isn't entered when i provide the high signals.
Am I missing some crucial code? Help is appreciated.
GPIO-EXTI
Interrupt
STM32L5 Series
TIM
‎2021-10-11 6:15 AM
‎2021-10-11 5:34 AM
Code seems okay to me. Should get an interrupt when PB6 goes from low to high.
If the code works on a Nucleo but not on your custom board, check to see if there are wiring issues. Make sure the PB6 pin itself is actually seeing the levels you expect.
‎2021-10-11 5:42 AM
Check linkage of routines via .MAP and listing files.
Confirm EXTI peripheral registers in debugger, or via telemetry data. Check event flagging
Confirm GPIO registers, reflect reporting in GPIOx->IDR for pin state.
‎2021-10-11 5:45 AM
I can messure the 5V directly at PB6. They are connected.
‎2021-10-11 6:14 AM
I am not quiet sure how to check the linkage of the routines and listing files.
I screenshoted for the other two ideas the Live Expressions before running, while running and while running with 5V connected.
There was no difference between 5V connected or disconnected.
‎2021-10-11 6:15 AM
‎2021-10-11 6:15 AM
‎2021-10-11 6:41 AM
Look like PB6 is high "before running" as well, so no transition, so no interrupt. What is pulling it down to 0V when the phototransistor is off?
‎2021-10-11 6:59 AM
I already tried it with the GPIO_InitStruct.Pull = GPIO_PULLDOWN; and without but it didnt make any difference.
‎2021-10-11 7:11 AM
If IDR reports it as high, and the voltage is 0V, there is a hardware issue. Note that pins are not 5V tolerant if VDD is not present.
