Ajay Kashyap
Visitor II
May 1, 2018
STM32L476XX CAN functionality Support?
  • May 1, 2018
  • 5 replies
  • 1182 views
Posted on May 01, 2018 at 04:19
I have purchased a
https://os.mbed.com/platforms/ST-Nucleo-L476RG/
 board for evaluating STM32L476XX MCU. However I am interested in the CAN functionality provided by the MCU and my question is do I need CAN transceiver
(for example an MCP2551 chip) to be able to communicate with a CAN Device or the CAN functionality available out of box with
STM32L476XX
MCU is sufficient to communicate with a CAN Device.
Thanks,
Ajay.
#stm32l476xx #can-interface #can
T J
Senior III
May 1, 2018
Posted on May 01, 2018 at 11:48
Usually you would need the line translator to talk to any normal CAN device.
but between nucleo boards for example, a diode circuit would suffice.
To start communicating on CAN, I suggest you purchase a transceiver and work on the receiver code first.
I used the CanDo unit.
Tesla DeLorean
Guru
May 1, 2018
Posted on May 01, 2018 at 14:34
Pro-Tip: Look at circuits used on EVAL series boards for examples of peripherals not provided on the NUCLEO boards.
Richard Li
May 31, 2018
Posted on May 31, 2018 at 22:55
Where is example code for STM32 MCU CAN bus master mode?
T J
Senior III
June 1, 2018
Posted on June 01, 2018 at 07:37
'its in the repository ' may or may not be true...
I would search for Canbus stm32L examples code in google...
We are here to help when you get stuck, it can take days to work on 1 small issue.
