STM32L44 is hanging
sindhu
if i load a 95KB code in stm32l44kcu6 controller ssd1306 display is hanging
Guru
With such limited information, it's unlikely anyone else will know what is going on more than you.
Most problems are caused by a bug in the code. I recommend debugging your code to find out why it's not working and to fix the issue.
Andrew Neil
Evangelist III
As @TDK said, you've given us next to nothing to go on!
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
Do you have any other code which does work on this system?
Does your code work on any other system?
