STM32L4 EXTERNAL INTERRUPT
semed abubakar
Posted on January 30, 2018 at 15:53
hello friends i recently got an stm32l4 I just go past the led blink i am trying my hands on interrupts I am trying to configure  a falling edge triggered interrupt on A0 and PC15 so far works fine for GPIOA but the interrupt for GPIOC15
is not working
I have enabled pull up on the pin but when i drive it low it doesnt trigger the interrupt during the debug i know cause the counter in the ISR is not incrementing
does anyone know why my c code is below i am using keil ide thank you
#include 'stm32l433xx.h'
extern int cnt,j;
void EXTI0_IRQHandler(void)
if (!(GPIOA->IDR & (1<<0)) )
if(!(cnt%2))
GPIOC->ODR =~(1<<4);
else
GPIOC->ODR|= (1<<4);
cnt++;
//Clear the EXTI pending bits
NVIC_ClearPendingIRQ(EXTI3_IRQn);
EXTI->PR1 |=(1<<0);
void EXTI15_IRQHandler(void)
j++;
NVIC_ClearPendingIRQ(EXTI15_10_IRQn); //Clear the EXTI pending bits
EXTI->PR1 |=(1<<15);
void Config_IO(void)
RCC->AHB2ENR |= RCC_AHB2ENR_GPIOBEN;
RCC->AHB2ENR |= RCC_AHB2ENR_GPIOCEN;
RCC->AHB2ENR |= RCC_AHB2ENR_GPIOAEN;
GPIOA->MODER &=~(1<<0); //input mode for A0
GPIOA->MODER &=~(1<<1);
GPIOA->PUPDR |= (1<<0); //pull up on A0
GPIOA->PUPDR &=~(1<<1);
GPIOA->OSPEEDR |=(1<<0); //input mode for A0
GPIOA->OSPEEDR |=(1<<1);
GPIOA ->OTYPER &=~(1<<0);
GPIOB ->MODER &= ~(GPIO_MODER_MODER13_0); // set GPIO 13 as general purpose input
GPIOB ->MODER &= ~(GPIO_MODER_MODER13_1);
GPIOB ->PUPDR &= ~(1<<27); //10000000000 Pull up RB13
GPIOB ->PUPDR |= (1<<26);
GPIOC ->MODER |= GPIO_MODER_MODE12_0; ///set GPIO13 as general output
GPIOC ->MODER &= ~(GPIO_MODER_MODE12_1);
GPIOC ->OTYPER &= ~(GPIO_OTYPER_OT_12); ///push pull output type for GPIOC12
GPIOC ->OSPEEDR |= (GPIO_OSPEEDER_OSPEEDR12_0); // high speed for GPPIOC12
GPIOC ->OSPEEDR |= (GPIO_OSPEEDER_OSPEEDR12_1);
GPIOC ->PUPDR &= ~(GPIO_PUPDR_PUPDR12); //NO PULL UP*/
GPIOC ->MODER |= (1<<8); //PC4 output mode
GPIOC ->MODER &= ~(1<<9);
GPIOC ->OTYPER |= (1<<4); //open drain on PC4
GPIOC ->OSPEEDR |= (1<<8); //PC4 high speed
GPIOC ->OSPEEDR |= (1<<9);
GPIOC ->PUPDR &=~(0<<8);
GPIOC ->PUPDR &=~(0<<9);
GPIOB->MODER &=~(1<<30); //input mode for B15
GPIOB->MODER &=~(1<<31);
GPIOB ->PUPDR &= ~(1<<31); //10000000000 Pull up B15
GPIOB ->PUPDR |= (1<<30);
GPIOB ->OTYPER &= ~(1<<15); ///push pull output type for GPIOB15
GPIOB ->OSPEEDR &= ~ (1<<30); //PB15 high speed
GPIOB ->OSPEEDR |= (1<<31);
void Config_Interrupt(void)
SYSCFG->EXTICR[0] &= SYSCFG_EXTICR1_EXTI0_PA;
SYSCFG->EXTICR[3] = SYSCFG_EXTICR4_EXTI15_PB ;
EXTI->IMR1 |= (1<<0);
EXTI->IMR1 |= (1<<15);
EXTI->EMR1 |=(1<<0); //interrupt source is unmaskrd
EXTI->EMR1 |=(1<<15); //Unmask interrupt line 15
EXTI->FTSR1 |= (1<<0); //falling edge line 1
EXTI->FTSR1 |= (1<<15); //falling edge line 15
__enable_irq(); //enable interrupt
NVIC_SetPriority(EXTI0_IRQn,4); //Set priority
NVIC_SetPriority(EXTI15_10_IRQn,4);
NVIC_ClearPendingIRQ(EXTI0_IRQn); //clear pending
NVIC_EnableIRQ(EXTI0_IRQn); ///enable interrupt
NVIC_EnableIRQ(EXTI15_10_IRQn);
void Config_IO(void);
void Config_Interrupt(void);
int cnt,i,j;
int main()
Config_IO();
Config_Interrupt();
while (1)
GPIOC->ODR|= (1<<12);
for(i=0;i<100;i++);
GPIOC->ODR&= ~(1<<12);
for(i=0;i<100;i++);
return 0;
Posted on January 30, 2018 at 17:14
void EXTI15_10_IRQHandler(void)
5 REPLIES 5
semed abubakar
Posted on January 30, 2018 at 18:03
Thank you waclawek i  i modified the code like you suggested i have changed the IRQ handler to
void EXTI15
_10_
IRQHandler(void)
  and i set
RCC_APB2ENR.SYSCFGEN in my config_io fucntion line 40
the interrupt is still not triggering i tried another pin PB3 but so far thats not working either  the code looks like this now
extern int cnt,j;
if(!(cnt%2))
else
cnt++;
EXTI->PR1 |=(1<<0);
cnt++;
j++;
void EXTI1_IRQHandler(void)
{ cnt++;
j++;
NVIC_ClearPendingIRQ(EXTI1_IRQn); //Clear the EXTI pending bits
EXTI->PR1 |=(1<<3);
RCC->APB2ENR |=(1<<0);                     //SYSCFG ENABLE
GPIOB ->OSPEEDR |= (1<<30); //PB15 high speed
GPIOB->MODER &=~(1<<6); //input mode for B3
GPIOB->MODER &=~(1<<7);
GPIOB ->PUPDR &= ~(1<<7); //10000000000 Pull up B3
GPIOB ->PUPDR |= (1<<6);
GPIOB ->OTYPER &= ~(1<<3); ///push pull output type for GPIOB3
GPIOB ->OSPEEDR |= (1<<6); //PB15 high speed
GPIOB ->OSPEEDR |= (1<<7);
SYSCFG->EXTICR[1] = SYSCFG_EXTICR4_EXTI15_PB ;
SYSCFG->EXTICR[1] = SYSCFG_EXTICR1_EXTI1_PB ;
EXTI->IMR1 |= (1<<3);
EXTI->EMR1 |=(1<<3);
EXTI->FTSR1 |= (1<<3);
NVIC_SetPriority(EXTI1_IRQn,4);
NVIC_EnableIRQ(EXTI3_IRQn);
extern int cnt,j;
if(!(cnt%2))
else
cnt++;
EXTI->PR1 |=(1<<0);
cnt++;
j++;
{ cnt++;
j++;
EXTI->PR1 |=(1<<3);
int cnt,i,j;
int main()
Config_IO();
Config_Interrupt();
while (1)
for(i=0;i<100;i++);
for(i=0;i<100;i++);
return 0;
Posted on January 30, 2018 at 17:25
and set RCC_APB2ENR.SYSCFGEN
Posted on January 31, 2018 at 10:24
Read back the SYSCFG and GPIO registers and check if they contain what you expect.
Look at the actual vector table (in binary, or better in disassembled binary) if the address at expected position points to the actual interrupt routine.
henry.dick
Senior II
Posted on January 31, 2018 at 12:11
the flow looks generally right. two suggestions:
1) simplify your code to a minimalist framework.
2) be consistent: if you are using pin13 as the exti, program your code so it consistently use that pin. I typically define a mask and use that mask throughout my code so if I want to move to a different pin, I can. your code has tons of hard-coded numbers that are inconsistent from one place to another, making it hard to track.
