STM32H745I-DISCO CM4 printf issue
‎2022-09-23 2:54 AM
I am using freeRTOS on dual-core of STM32H745I disco dev-kit.
Where I am able to print debug messages using "printf" function in core M7 using UART3 but not able to print messages using "printf" function.
I have followed the https://community.st.com/s/article/how-to-redirect-the-printf-function-to-a-uart-for-debug-messages steps.
Also, I have done changes when I want to use UART3 for core M4. : Disabled UART3 on M7 and initialized(enabled) in M4 using "MainSTM32.ioc". Still, I am facing issue.
STM32H7 Series
UART-USART
‎2022-09-23 3:06 AM
You're going to need to be less vague..
Lead with details.
W​orks here in Keil.
‎2022-09-23 3:10 AM
I am using STM32cubeIDE 1.8.0
‎2022-09-29 3:00 AM
Hello ST team @Amel NASRI
I still facing this issue is there any solution?
‎2022-10-05 2:06 PM
Do you even understand yourself? And you have not explained anything useful, therefore nobody can help you.
‎2022-10-06 12:37 AM
@Piranha​,
Thanks for your reply.
If you read properly my post then you can find that I have mentioned one link and I have followed the same steps for core CM7 where printf works fine.
Also, I have done changes when I want to use UART3 for core M4. : Disabled UART3 on M7 and initialized(enabled) in M4 using "MainSTM32.ioc". Still, I am facing the issue.
Whenever I followed the same steps for Core M4 then I am facing printf issue like the one below.
I want to print "printf("\n\nGetting run time cpu usage over %ld ticks\n", STATS_TICKS);"(in my firmware)
But the actual print on UART(Tera Term) is "Gttting r n time upu usago over 1000 ticks|"
So that is the issue I am facing
Thanks!
