STM32H745 does not generate SPI clock signal when it is set to 60 Mhz ?
I have a 250 Mhz oscilloscope. I am analyzing SPI clock signals at different speeds. Once I tried to have a maximum clock speed for SPIs in H745, I cant see anything from the clock pins. When I set the prescaler to 4(30Mhz) or 8(15Mhz) I can see the clock singal and everything works fine. Does anybody know about this issue ?
Best Regards.
