STM32H743 Using of Multichannel ADC Triggered by Timer in Interrupt Mode
Ey.1
I'm having a trouble when using multichannel ADC. In my application there is 2 ADC which contains 7 channels. In ADC Interrupt Callback, I'm pushing the read data to array of 7 elements. But I couldn't see the proper value in proper element of array, they are sliding in the array countinously.
Each ADC contain seven ACS725. So there is no High-Z situation. I'm seeing at the pins 0.5V constant (zero current) . My callback and init part is in above. Thanks a lot for your help!
/* ADC3 init function */
void MX_ADC3_Init(void)
  ADC_ChannelConfTypeDef sConfig = {0};
  /** Common config
  hadc3.Instance = ADC3;
  hadc3.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV4;
  hadc3.Init.Resolution = ADC_RESOLUTION_16B;
  hadc3.Init.ScanConvMode = ADC_SCAN_ENABLE;
  hadc3.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
  hadc3.Init.LowPowerAutoWait = DISABLE;
  hadc3.Init.ContinuousConvMode = DISABLE;
  hadc3.Init.NbrOfConversion = 7;
  hadc3.Init.DiscontinuousConvMode = DISABLE;
  hadc3.Init.ExternalTrigConv = ADC_EXTERNALTRIG_T15_TRGO;
  hadc3.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
  hadc3.Init.ConversionDataManagement = ADC_CONVERSIONDATA_DR;
  hadc3.Init.Overrun = ADC_OVR_DATA_OVERWRITTEN;
  hadc3.Init.LeftBitShift = ADC_LEFTBITSHIFT_NONE;
  hadc3.Init.OversamplingMode = DISABLE;
  if (HAL_ADC_Init(&hadc3) != HAL_OK)
    Error_Handler();
  /** Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_0;
  sConfig.Rank = ADC_REGULAR_RANK_1;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  sConfig.SingleDiff = ADC_SINGLE_ENDED;
  sConfig.OffsetNumber = ADC_OFFSET_NONE;
  sConfig.Offset = 0;
  sConfig.OffsetSignedSaturation = DISABLE;
  if (HAL_ADC_ConfigChannel(&hadc3, &sConfig) != HAL_OK)
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = ADC_REGULAR_RANK_2;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_2;
  sConfig.Rank = ADC_REGULAR_RANK_3;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_3;
  sConfig.Rank = ADC_REGULAR_RANK_4;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_6;
  sConfig.Rank = ADC_REGULAR_RANK_5;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_7;
  sConfig.Rank = ADC_REGULAR_RANK_6;
    Error_Handler();
  sConfig.Channel = ADC_CHANNEL_8;
  sConfig.Rank = ADC_REGULAR_RANK_7;
    Error_Handler();
void HAL_ADC_ConvCpltCallback(ADC_HandleTypeDef* hadc)
	if(__HAL_ADC_GET_FLAG(&hadc1, ADC_FLAG_EOC))
		g_internalAdc1.m_rawResultArray[cntAcs1++] =  (uint16_t) HAL_ADC_GetValue(hadc);
		if(cntAcs1 == g_internalAdc1.MS_NUMBER_OF_CHANNEL)
			cntAcs1 = 0;
			g_internalAdc1Ready = true;
	if(__HAL_ADC_GET_FLAG(&hadc3, ADC_FLAG_EOC))
		g_internalAdc2.m_rawResultArray[cntAcs2++] = (uint16_t) HAL_ADC_GetValue(hadc);
		if(cntAcs2 == g_internalAdc2.MS_NUMBER_OF_CHANNEL)
			cntAcs2 = 0;
			g_internalAdc2Ready = true;
In SystemClock_Config function:
PeriphClkInitStruct.AdcClockSelection = RCC_ADCCLKSOURCE_PLL3; //129Mhz (  (I also tried other options)
My timer also adjusted to 40ms period.
In debug, what I mean results are sliding in the array :
etc...
(while ~7000 raw data is zero current, ~14000 is equalt to 1.2 Amper. I'm applying the 1.2A to only one channel that has to be in the 3rd element of the array)
After I tried with a new project with applying same configurations with using only 2 channel: I aware that there is only 1 conversion result. The other result does not seen on the callback and also DR register. And when I start the ADC with software(without timer trig) it looks like it takes the result from random channel. I could not solve problem for three days.
Thanks again.
4 REPLIES 4
Hello
ADC1 and ADC3 have different IRQ handlers and different NVIC priorities (one interrupts the other)
Inside completion_callback dont check for eof flag.
Check the handle
if(hadc==&hadc1) {;}
else if (hadc==&hadc3)
else{;} //whatelse
The Fadc is about 32Mhz .Is BOOST bit(s) set? (boost functionality differentiates with chip revision Y or V)
Thanks for reply! I changed the conditions in callback like you say. I was not aware of boost mode, it was on reset state. My chip is V revision, and I set the these two bits and I also observe in SFRs they changed to true state. But there is no timing differences.
Ey.1
When in continuous mode, disabling the timer trigger, values always sliding in the array :(
Ey.1
In DMA mode, disabling adc global interrupt, it is working in a true way. But in interrupt mode, I could not handle.
