STM32G071C8T6 and USART3
gh_rcl
Hi All,
I don't managed to send char on USART3 with the attached project.
I was wondering if someone had already detected issue in using USART3
Thanks in advance
3 REPLIES 3
Where in the code are you transmitting and how?
What hardware are you using? Did you observe the Tx pin using oscilloscope?
Read out and check/post the relevant USART and GPIO registers content.
Your code doesn't attempt to send anything. It initializes the peripheral but never uses it.
  MX_GPIO_Init();
  MX_USART3_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
Lots of examples out there to follow:
https://github.com/STMicroelectronics/STM32CubeG0/blob/5cb06333a6a43cefbe145f10a5aa98d3cc4cffee/Projects/NUCLEO-G071RB/Examples/UART/UART_TwoBoards_ComPolling/Src/main.c
gh_rcl
Thanks for your feedback.
Indeed i attached the wrong file.
Anyway i found the issue. Indeed by setting Tx and Rx as output, i noticed that only Rx was OK.
By testing with another board it works.
Thanks again for your time.
gh_rcl
