STM32G0/L4/etc. ADC "CALFACT" is obviously some calibration factor, but how do you translate the 7 bits into a numerical value that multiplies the result? Reference manual does not seem to want to say.
jeffl.kelley9
3 REPLIES 3
It is used internally by the ADC during conversion, i.e. you don't use it to modify the conversion result.
jeffl.kelley9
It is used internally during a conversion and is some sort of multiplication factor. What I am after is how to translate the CALFACT number into the actual amount results are multiplied by.
That's not documented.
You may be mistaken in considering it to be a multiplier.
Why can't you use the ADC as intended and as described?
