2016-10-20 02:05 AM
Despite several promises to keep us informed about the findings around the error with RMII in F76, only ''ask your FAE'' was posted here. Now silently Rev. 3 of the F76 errata appeared, stating ''No workaround''.
Does anybody have a hack to work somehow reliable with RMII on F76, as on the Nucleo-F769? Thanks B.t.w.: It is no more possible to reply to the threads around ETH on F76 that were posted not even a month ago. Trying to reply, ''404'' is received as answer. It is not good, if people bring up really old threads, but not even a month is a time span to short i.m.h.o.2016-10-20 02:34 AM
I've just [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Discovery/Stm32F767%20Nucleo%20Ethernet%20does%20not%20always%20start&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F¤tviews=94]succeeded to do so. The 404 might've been one of the many of this forum software's quirks. JW2016-10-20 03:43 AM
We confirm the Ethernet limitations as described in .We would like to inform you that a new device revision will be available to fix these limitations.For more details, please contact your FAE or distributor.-STM32 Forums ModeratorTo give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
2016-10-26 09:16 AM
The limitation ''Ethernet erroneous data received in RMII configuration'' is fixed in Revision Z of the STM32F76xxx and STM32F77xxx (see ).-STM32 Forums ModeratorTo give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
