2015-10-10 07:05 AM
2015-10-13 01:16 AM
Well I solved the problem of communicating through I2C with using HAL library. The problem was an acknowledge flag I solved it changing the I2C channel; channel 1 seems to be bad for some reason.
If someone is having the same problem fell free to ask.2016-03-02 05:59 AM
2016-09-12 01:50 AM
Hello Iker;
I am working with the ADXL345 too. Could you share with me your .h files? I would like to read te registers of the device and mi code is not working.
