Stm32f407vgtx TIM output compare mode
‎2025-06-26 6:51 AM - last edited on ‎2025-07-01 5:59 AM by mƎALLEm
Hi
I am trying to achieve output compare mode in TIM1 in stm32f407vgtx board .
I am trying to generate a delay of one ms and running a timer clock at 1mhz after divide it with prescaler.
I have enabled upcounter,TIM_CCER_CC1E bit in CCER, TIM_EGR_CC1G bit and loaded CCR1 as 999(one ms) and ARR as 0xFFFF but my counter is exceeding the value and it is going upto 65535 which is the ARR value .
I have not configured OC1M[2:0]bit (capture/compare mode register 1 (TIMx_CCMR1)) as I am not toggling PA8 or any thing on that pin which is linked with TIM1_CH1.
I want when ever counter value matches CCR1 it generates interrupt and I am toggling led inside that IRQ handler.
Can you help me where I am wrong please.
B.R
Ashish
- Labels:
STM32F4 Series
TIM
‎2025-07-01 5:58 AM - edited ‎2025-07-01 5:58 AM
Hi @Ash1,
This is normal as TIM1 counter continues counting up to the value set in the ARR register, which in your case is 0xFFFF. The CCR1 value is only a reference for comparison.
You need to:
- Generate an interrupt on CCR1 match, enable CC1IE and configure OC1M = 000, CC1E = 0.
- You do not need to toggle the output pin for the interrupt to work.
- In your IRQ handler, clear the CC1IF flag and toggle your LED
Hi @Ash1,
You need to:
