STM32F405 using dual USB host
‎2025-02-07 3:21 AM
I'm new to the ST32 world and would like to know if this is possible before I start experimenting with an STM32F405:
Is it possible to use both USB interfaces as a USB host at the same time (only full speed and low speed, no high speed is required)
For example, to connect a mouse to one USB port and a keyboard to the other USB port.
If so, can I just use D+/D- of the ports, or do you need additional external components for the high-speed port also when I use it in HS/LS mode?
If that works, is there any example software to use 2 HID hosts in parallel? Is there an evaluation board that has USB ports?
- Labels:
STM32F4 Series
USB
‎2025-02-07 3:37 AM
AN4879, Introduction to USB hardware and PCB guidelines using STM32 MCUs:
via: https://www.st.com/en/microcontrollers-microprocessors/stm32f405zg.html#documentation
‎2025-02-07 3:37 AM
‎2025-02-07 6:58 AM
Perfect, thanks!
‎2025-02-10 5:29 AM
Hi @Lowlanders
It is not possible to connect more than one device to the same USB port configured as a host. Actually, hub operation is not supported.
‎2025-02-10 6:01 AM
Yes, I know. One device per USB port. So I should be able to connect a total of 2 devices to the ST32F405.
This's all I want. And I hope that I can connect LS and FS devices without any problems.
