STM32F4 - Watchdog in STANDBY mode
‎2019-02-13 4:25 AM
After reading some applications note I did't find the way to implement a watchdog for my case.
My case:
- the MCU shall sleep during 12h
- one function on Bluetooth stack in a .a (provided by TI) takes 1024ms
- MCU is running at 48MHz
WWDG can't be used because some functions take more than 100ms.
I see that IWDOG can be stopped ?!
Somethime I have a problem with interrupt from UART and USB, MCU stay on these interrupt and my Main loop is not proceced...
How can I do to have a watchdog @ 5000ms disabled when I'm in STANDBY mode ?
Thanks for help.
Power
STM32F4 Series
‎2019-02-15 7:27 AM
You can disable the IWDG when in standby mode only if you use an microcontroller with the option byte "IWDG_STDBY".
IWDG_STDBY:
- If you set this option byte the independent watchdog counter is running in standby mode
- If you reset this option byte the independent watchdog counter is frozen in standby mode
Best Regards,
Mohamed Aymen.
‎2019-02-15 7:54 AM
Thanks for support.
The microcontroller STM32F415 doesn't have this option bit.
‎2019-02-18 5:19 AM
In order to exploit this feature, you must use a microcontroller with this option byte .
Best Regards,
Mohamed Aymen.
‎2023-05-13 10:13 PM
hi, please suggest me about product series name of option byte with i watchdog +standby availability
from which series above mentioned option available .
