STM32F107VG PB3 - PB4 - PA15 Alternate Function Usage
‎2012-07-13 1:37 AM
Hello
I have to use PB3 - PB4 - PB5 alternate function for using SPI3 or SPI1 But these pins are looking on JTAG main function after reset on datasheet.These pins are still working on jtag main function I can't change that.How can I solve this problem ?SPI Configuration is : void sFLASH_Init(void){ SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; // &sharpifdef USE_STM3210C_EVAL//// /* Enable SPI3 Pins Software Remapping */// GPIO_PinRemapConfig(GPIO_Remap_SPI3, ENABLE);//&sharpendif /* Configure SPI_MASTER pins: SCK, MISO and MOSI */ GPIO_InitStructure.GPIO_Pin = sFLASH_SPI_SCK_PIN | sFLASH_SPI_MISO_PIN | sFLASH_SPI_MOSI_PIN; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(sFLASH_SPI_GPIO_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = sFLASH_CS_PIN; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(sFLASH_CS_GPIO_PORT, &GPIO_InitStructure); /* 1 bit for pre-emption priority, 3 bits for subpriority */ NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4); /* Configure and enable SPI_MASTER interrupt -------------------------------*/ NVIC_InitStructure.NVIC_IRQChannel = SPI3_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; SPI_InitStructure.SPI_Mode = SPI_Mode_Master; SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_32; SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; SPI_InitStructure.SPI_CRCPolynomial = 7; SPI_Init(sFLASH_SPI, &SPI_InitStructure); SPI_I2S_ITConfig(sFLASH_SPI, SPI_I2S_IT_TXE, ENABLE); /* Enable SPI_SLAVE RXNE interrupt */ SPI_I2S_ITConfig(sFLASH_SPI, SPI_I2S_IT_RXNE, ENABLE); SPI_Cmd(sFLASH_SPI, ENABLE); sFLASH_CS_HIGH();}RCC Configuration :void RCC_Configuration(void){ /* PCLK2 = HCLK/2 */ RCC_PCLK2Config(RCC_HCLK_Div2); /* Enable peripheral clocks --------------------------------------------------*/&sharpifdef USE_STM3210C_EVAL /* Enable GPIO clock for SPI_MASTER and SPI_SLAVE */ RCC_APB2PeriphClockCmd(sFLASH_SPI_GPIO_CLK | //SPI_SLAVE_GPIO_CLK | RCC_APB2Periph_AFIO, ENABLE); RCC_APB2PeriphClockCmd(sFLASH_CS_GPIO_CLK | RCC_APB2Periph_AFIO ,ENABLE); /* Enable SPI_MASTER Periph clock */ RCC_APB1PeriphClockCmd(sFLASH_SPI_CLK, ENABLE); &sharpendif}Pin Defines are : &sharpdefine sFLASH_SPI SPI3 &sharpdefine sFLASH_SPI_CLK RCC_APB1Periph_SPI3 &sharpdefine sFLASH_SPI_SCK_PIN GPIO_Pin_3 &sharpdefine sFLASH_SPI_MISO_PIN GPIO_Pin_4 &sharpdefine sFLASH_SPI_MOSI_PIN GPIO_Pin_5 &sharpdefine sFLASH_CS_PIN GPIO_Pin_1 &sharpdefine sFLASH_SPI_GPIO_PORT GPIOB &sharpdefine sFLASH_SPI_GPIO_CLK RCC_APB2Periph_GPIOB &sharpdefine sFLASH_CS_GPIO_PORT GPIOE &sharpdefine sFLASH_CS_GPIO_CLK RCC_APB2Periph_GPIOE #spi #jtag-pb4-remap #stm32- Mark as New
‎2012-07-13 3:19 AM
Hi, I'm using the same MCU and I found some register calculations mistakes for the AF using GPIOI and SPI2. maybe could be the same. check the register value after setting the AF.
my post is here/33f7a5db
regards- Mark as New
‎2012-07-13 4:00 AM
I can use SPI2 normally
But I have to use SPI1 or SPI3 , so these pins are jtag pins at the main function after reset, i try to use normally I/O pin .So I have to Remap these pins for usage I/O .- Mark as New
‎2012-07-13 4:54 AM
You aren't using the same MCU, the F107 uses unit based peripheral remapping, L1xx, F2xx and F4xx use PIN based remapping. Your problem related to a common coding error.Up vote any posts that you find helpful, it shows what's working..
‎2012-07-13 6:17 AM
Clive
How can i remap these pins from jtag to use SPI pins ? I couldn't use SPI related to this problem I can't find any command about this/* Enable GPIO clock for SPI_MASTER and SPI_SLAVE */
///////////////////////////////////////////////////////////////////////////////SPI_InitTypeDef SPI_InitStructure;
Where i do mistake ?- Mark as New
‎2012-07-13 7:38 AM
For GPIO it works like this
/* Disable the Serial Wire Jtag Debug Port SWJ-DP */
GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable, ENABLE);
/* Configure PA.13 (JTMS/SWDAT), PA.14 (JTCK/SWCLK) and PA.15 (JTDI) as
output push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure PB.03 (JTDO) and PB.04 (JTRST) as output push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4;
GPIO_Init(GPIOB, &GPIO_InitStructure);
You might be able to use GPIO_Remap_SWJ_JTAGDisable as it's just the JTAG pins you want to free up, and providing you only connect the SWD signals to your debug header.
RCC_APB2PeriphClockCmd(sFLASH_SPI_GPIO_CLK | sFLASH_CS_GPIO_CLK | RCC_APB2Periph_AFIO, ENABLE); // GPIOB & GPIOE
RCC_APB1PeriphClockCmd(sFLASH_SPI_CLK, ENABLE); // SPI3
GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE); // Requires AFIO clock enabled, Map JTAG Off pins PB3,4,5, SWD still viable on PA13,14
/* Configure SPI3 pins: SCK, MISO and MOSI PB3,4,5 */
GPIO_InitStructure.GPIO_Pin = sFLASH_CS_PIN; // PE.1
‎2012-07-16 12:57 AM
It works clive thanks alot
‎2013-01-02 6:41 PM
Guy's try this magic sequence. And remember that JTAG pins should be the last in remap sequence, because it's not able to read them.
GPIO_PinRemapConfig(GPIO_Remap_SWJ_NoJTRST, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);- Mark as New
‎2015-01-22 1:32 AM
Thank You it actually works great !
‎2016-01-04 6:12 PM
thank you clive 1
