2024-01-22 04:49 AM
According to AN2606 section 12 we can use USB DFU bootloader as long we have HSE using a 24, 18, 16, 12, 8, 6, 4 MHz crystal. This is missing from section 3.3 of the datasheet. Is there a reason for this?
2024-01-22 05:48 AM
Hello
Thank you for bringing this issue to our attention.
I confirm that we need to add USB DFU bootloader to the datasheet. I reported internally.
Internal ticket number: 171357 (This is an internal tracking number and is not accessible or usable by customers).
Best Regards.
STTwo-32
2024-01-22 05:48 AM
Hello
Best Regards.
STTwo-32
2024-01-22 06:10 AM
Thanks for pointing this out.
