STM32CubeMX v4.25.0 - uknown host server name
Posted on March 12, 2018 at 20:32
Whenever you want to update something you get:
I see also this problem when trying to open a project from v4.24.0, and when generating new project for an IDE.
In those cases the message is slightly different but still about problems with server connectivity.
7 REPLIES 7
Posted on March 12, 2018 at 20:43
Checked:
- 'no proxy' at home, and proxy at work
- 'check connection' button works fine (is GREEN)
- when you try to check update the 'check connection' becomes RED
Davydenko.Sergey
Posted on March 13, 2018 at 09:26
I also have this problem ...
Davydenko.Sergey
Posted on March 13, 2018 at 09:37
so much to just write a break
Posted on March 13, 2018 at 09:31
Good to hear it! I was afraid that I am the only one...
Posted on March 13, 2018 at 18:09
Just tested it again and the server is available now. What about you?
Davydenko.Sergey
Posted on March 14, 2018 at 09:23
Good. It worked...
Posted on March 14, 2018 at 09:29
It seems like the issue on the ST Server side...
