STM32CubeMX - OCTOSPI configuration
rsun.11
When I used STM32CubeMX to do the parameter setting. For some of the parameters I don't know how to configure them. For example, the parameters like: "Chip select high time", "Chip select boundary", "Refresh rate". How to configure the above three parameters in combination with the datasheet?
ChahinezC
Lead
Hello @rsun.1​,
I recommend you checking the "Table 5. STM32CubeMX - Configuration of OCTOSPI parameters" of the AN5050, it will help you.
If this solves your problem, please mark my answer as "Best Answer" by clicking on the "Select as Best" button, this can be very helpful for Community users to find this solution faster.
Regards,
Chahinez.
1 REPLY 1
ChahinezC
Lead
Hello @rsun.1​,
Regards,
Chahinez.
