STM32 external SRAM memory compatibility
FlorentNapoleoni
As part of a board re-design due to obsolescence,I need to find a replacement for the existing microprocessor and my choice is the STM32F429.
Because of its 32-bit flexible memory controller (FMC). I wanted to know if there is a document specifying which memory references are compatible with the STM32F429 memory controller.
If not, I wanted to know whether the following reference might be compatible with the FMC : CY7C1041G30-10ZSXI
My question concerns SRAM memory read/write times.
Thank you for your help.
Best Regards,
Florent Napoleoni
0 REPLIES 0
