Spi clocks are 4, 5, 6 instead of 8 bits
‎2025-02-23 8:19 AM
Hi all
I am using the stm32h743 device when using spi 6 to transmit data the clocks
are 4, 5, 6 randomly instead of 8 bits
when configuring spi2 the processor function perfectly.
on this device I have already used
connection: SPI1, SPI5, ethernet, uart4.uart7,uart8, usart1,usart2,usart3
middleware and software package: freertos, LWIP
Timers: Timer1
System core: DMA, GPIO,NVIC, RCC, SYS
CubeMx Version 6.13
CubeIDE 1.16.0
Repository: 1.12.0
Thank you for you answer
- Labels:
STM32H7 Series
‎2025-02-24 7:24 AM
I have checked all 6 SPI to be configured as transmits master only 8 bit frame prescaler 256
only spi 6 behave sending 4 or 5 or 6 clocks instead of 8
‎2025-02-25 12:14 AM
Solution : if spi 6 clock is located on pa5 then this error will happen
relocate spi 6 clock to other pin and the problem mention before we be removed
‎2025-02-25 12:51 AM
If the "problem" only happens on one particular pin, that's probably due to a conflict on the board ...
You haven't said what board you're using.
Check your schematics. If it's a custom board, also check for manufacturing faults/errors; eg, shorts.
Maybe get a logic analyser trace which shows SPI6 working (clock on a pin other than PA5), plus what's happening on PA5 - so a total of 5 signals: NSS, SCK, MOSI, MISO, PA5.
‎2025-02-25 1:03 AM
I am using stm32h743 evaluation board the pin are only connected to the logic analyzer
the board was replaced, to see if the problem was on a particular board.
i am in master transmit only mode only clock and mosi (data) pins are used.
‎2025-02-25 1:10 AM
@dorong wrote:I am using stm32h743 evaluation board .
Which one, exactly?
This: https://www.st.com/en/evaluation-tools/stm32h743i-eval.html ?
@dorong wrote:i am in master transmit only mode only clock and mosi (data) pins are used.
So just look at SCK, MOSI, and PA5.
‎2025-02-25 1:33 AM
@Andrew Neil wrote:This: https://www.st.com/en/evaluation-tools/stm32h743i-eval.html ?
If so, did you remove R118?
also on the schematics:
‎2025-02-25 2:38 AM - edited ‎2025-02-25 2:39 AM
stm32h743i-eval2
‎2025-02-25 3:00 AM
So that is one covered by the Manual I linked:
So, again, did you remove R118 ?
If not, that explains why you couldn't use PA5!
- « Previous
- 1
- 2
- Next »
