Slow RTC
sergiorp89
Posted on January 19, 2016 at 11:31
Hi all,
I'm using the RTC to send data every few minutes, but after a while I saw that the shipments are carried out each longer than scheduled but ntp number sent by my stm were correct as I wanted. Then I compared the measures of the RTC with HAL_GetTick() measured . For a 10 minutesRCT alarm I get 65583 milliseconds. My RTC is almost 10% slower. Does anyone know this may be due? Im using Lsi. <code>
PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC|RCC_PERIPHCLK_ADC;
PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSI;
PeriphClkInit.AdcClockSelection = RCC_ADCPCLK2_DIV2;
if
(HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
Error_Handler();
void
MX_RTC_Init(
void
/** Initialize RTC **/
RtcHandle.Instance = RTC;
RtcHandle.Init.AsynchPrediv = RTC_AUTO_1_SECOND;
RtcHandle.Init.OutPut = RTC_OUTPUTSOURCE_NONE;
if
(HAL_RTC_Init(&RtcHandle) != HAL_OK)
/* Initialization Error */
Error_Handler();
void
HAL_RTC_MspInit(RTC_HandleTypeDef* hrtc)
if
(hrtc->Instance==RTC)
/* USER CODE BEGIN RTC_MspInit 0 */
/* USER CODE END RTC_MspInit 0 */
/* Enable BKP CLK enable for backup registers */
__HAL_RCC_BKP_CLK_ENABLE();
HAL_PWR_EnableBkUpAccess();
/* Peripheral clock enable */
__HAL_RCC_RTC_ENABLE();
/* USER CODE BEGIN RTC_MspInit 1 */
HAL_NVIC_SetPriority(RTC_Alarm_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(RTC_Alarm_IRQn);
/* USER CODE END RTC_MspInit 1 */
static
void
RTC_TimeConfigNTP(
void
RTC_DateTypeDef sdatestructure_set = {0};
RTC_TimeTypeDef stimestructure = {0};
SNTP_Timestamp_t ntpTime;
NetTime_t extractedTime;
sntp_NTPGetTime(&ntpTime, 0);
sntp_ExtractNTPTime(&ntpTime, &extractedTime);
/*##-1- Configure the Date #################################################*/
sdatestructure_set.Year = extractedTime.year % 100;
//Introducimos solo los dos ultimos numeros
sdatestructure_set.Month = extractedTime.mon;
sdatestructure_set.Date = extractedTime.mday;
if
(HAL_RTC_SetDate(&RtcHandle,&sdatestructure_set,RTC_FORMAT_BIN) != HAL_OK)
Error_Handler();
/*##-2- Configure the Time #################################################*/
stimestructure.Hours = extractedTime.hour;
stimestructure.Minutes = extractedTime.min;
stimestructure.Seconds = extractedTime.sec;
if
(HAL_RTC_SetTime(&RtcHandle,&stimestructure,RTC_FORMAT_BIN) != HAL_OK)
Error_Handler();
static
void
RTC_AlarmConfigNTP(
void
uint8_t hoursAlarm = 0;
uint8_t minutesAlarm = 1;
uint8_t secondsAlarm = 0;
RTC_AlarmTypeDef salarmstructure = {{0}, 0};
RTC_AlarmTypeDef sprealarmstructure = {{0}, 1};
if
(sprealarmstructure.AlarmTime.Hours== 0 && sprealarmstructure.AlarmTime.Minutes == 0 && sprealarmstructure.AlarmTime.Seconds==0 ){
HAL_RTC_GetTime(&RtcHandle, &stimestructure, RTC_FORMAT_BIN);
sprealarmstructure.Alarm = RTC_ALARM_A;
sprealarmstructure.AlarmTime.Hours = stimestructure.Hours;
sprealarmstructure.AlarmTime.Minutes = stimestructure.Minutes;
sprealarmstructure.AlarmTime.Seconds = stimestructure.Seconds;
//HAL_RTC_GetTime(&RtcHandle, &stimestructure, RTC_FORMAT_BIN);
//HAL_RTC_GetDate(&RtcHandle, &sdatestructure_set, RTC_FORMAT_BCD);
/*##-3- Configure the RTC Alarm peripheral #################################*/
salarmstructure.Alarm = RTC_ALARM_A;
salarmstructure.AlarmTime.Hours = (sprealarmstructure.AlarmTime.Hours+((sprealarmstructure.AlarmTime.Minutes+((sprealarmstructure.AlarmTime.Seconds
+secondsAlarm)/60)+minutesAlarm)/60)+hoursAlarm)%24;
salarmstructure.AlarmTime.Minutes = (sprealarmstructure.AlarmTime.Minutes+((sprealarmstructure.AlarmTime.Seconds
+secondsAlarm)/60)+minutesAlarm)%60;
salarmstructure.AlarmTime.Seconds = (sprealarmstructure.AlarmTime.Seconds+secondsAlarm)%60;
if
(HAL_RTC_SetAlarm_IT(&RtcHandle,&salarmstructure,RTC_FORMAT_BIN) != HAL_OK)
Error_Handler();
Sorry for such a precarious code. #stm32 #rtc
2 REPLIES 2
Radosław
Senior II
Posted on January 19, 2016 at 12:37
Look in datasheet for LSI characterization
Posted on January 19, 2016 at 14:42
Benchmark your LSI against a crystal source, and then configure the RTC dividers appropriately. Don't use the default settings.
