Simple Multicore Core to Core Communication with STM32H7
‎2024-09-06 12:41 AM
Hello Team,
how can a simple core to core communication on the STM32H7 be implemented? We want to exchange 2kByte of data in bidirectional way between CM7 and CM4.
Best regards,
Jochen
- Labels:
STM32H7 Series
‎2024-09-08 9:58 PM
Where do I find the places in the code for the data array (memory) which is exchanged?
Is the same data array used for both exchanged data between the 2 cores?
‎2024-09-09 1:53 AM
Is there any simpler solution available for the shared mermory access? We just want to exchange 2KByte of data between the 2 cores.
‎2024-09-09 2:16 AM
Or just create a shared memory region common to the two cores on each Core's linker. But you need to ensure at least two things:
- Synchronization of read and write operation between the two cores using HSEM to ensure the consistency of the data.
- Either to manage the data coherency from CM7 side when Cache is enabled or declare that region as Strongly-Ordered or Device (non cacheable) using MPU.
- « Previous
- 1
- 2
- Next »
