Scanning multiple channels using polling on STM32f401Re
‎2021-07-26 10:54 PM
Dear ST community,
I am using ADC to measure different voltages and I need a total of 15 channels and I need to measure ADC in a polling mechanism. When I use
HAL_ADC_GetValue(&hadc1);
It gives me value for only one ADC channel I am unable to receive values for other ADC channels. Can you all please help me how to scan multiple ADC channels using polling.
My ADC configuration is as follows.
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
ADC_ChannelConfTypeDef sConfig = {0};
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.ScanConvMode = ENABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.NbrOfConversion = 15;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_15CYCLES;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
sConfig.Rank = 2;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_3;
sConfig.Rank = 3;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = 4;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
sConfig.Rank = 5;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_6;
sConfig.Rank = 6;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_7;
sConfig.Rank = 7;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_8;
sConfig.Rank = 8;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_9;
sConfig.Rank = 9;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_10;
sConfig.Rank = 10;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_11;
sConfig.Rank = 11;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_12;
sConfig.Rank = 12;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_13;
sConfig.Rank = 13;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_14;
sConfig.Rank = 14;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_15;
sConfig.Rank = 15;
Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
My main code is as follows
while (1)
while(interrupt_state == TRUE)
HAL_ADC_Start(&hadc1);
for(int i = 0; i< Max_Channels; i++)
//HAL_ADC_Start(&hadc1);
HAL_ADC_PollForConversion(&hadc1, HAL_MAX_DELAY);
adcValue[i] = HAL_ADC_GetValue(&hadc1);
counter++;
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
if(interrupt_state == FALSE)
printf("Counter value is: %d\r\n",counter);
interrupt_state = TRUE;
counter = 0;
/* USER CODE END 3 */
ADC
STM32F4 Series
‎2021-07-27 01:30 AM
Hello ,
You can check the wealth of videos on the subject on youtube channel: There are many examples of STM32 ADC Poll and DMA multi channel
You can also get inspiration from the ADC examples for your target series (under the folder Projects in the firmware package).
Imen
‎2021-07-27 07:16 AM
Converting more than one channel at a time requires the use of DMA. Otherwise, you will need to convert one channel at a time and change the channel being converted afterwards.
There are lots of examples in the Cube repository.
