"Failed to execute MI command.... Load failed ... LTDC_Paint.elf" , see also attachment.
Which configuration did I miss?
2022-09-09 6:37 AM
I bought the STM32H750B Discovery and wanted to program a first example "LTDC Paint" on the demo to start.
I am using the STM32Cube IDE version 1.9 (default installation, no changes made).
Procedure:
- File -> New -> STM32 Project -> Examples -> select the Discovery Board -> select the LTDC Paint example -> Run LTDC Paint
Then I get the following error message, see attachment:
- Labels:
LCD-LTDC
STM32CubeIDE
STM32H7 Series
2022-09-12 9:29 AM
Hello @pk84
First let me thank you for having reported.
In fact I could reproduce the issue you have encountered.
And after further analysis I observed that the used example in this case use an external memory.
In this case you should set the Debug configuration in the CubeIDE to accommodate this.
- Go to the Debug Configuration
- Click on "SCAN" button and select the adequate external loader for the "MT25TL01G_STM32H750B-DISCO, 0x90000000, NOR_FLASH, MT25TL01G_STM32H750B-DISCO.stldr"
Feel free to repost about the efficacity of this solution.
Your feedback will be very helpful.
Kind regards,
Semer.
2022-09-11 11:37 PM
I would appreciate any little hint/tip?
2022-09-12 9:29 AM
Hello @pk84
Kind regards,
Semer.
2022-09-13 6:23 AM
Thanks, I will try this solution as soon as possible.
Still one question:
1) What if I want change the pin-configuration of the connected QSPI-Flash (in case of a customized board) ? Where can I do this? I ask because there is no QSPI driver file in the LTDC example.
2022-09-15 7:24 AM
Hello @pk84
My bad I forgot to mention this part in my reply.
In fact since the example project is stored and executed from external memory you need to flash the "ExtMem_Boot".
The boot project take care of the init of the QSPI interface.
The boot project could be found under "STM32Cube_FW_H7_V1.10.0\Projects\STM32H750B-DK\Templates".
Import the "ExtMem_Boot" to CubeIDE and build it.
Go to the debug configuration for the LTDC Paint example project and under [Startup] add the download of the ExtMem_Boot" binary. (check screenshot bellow)
Kind regards,
Semer.
2024-05-28 3:22 AM
I am facing same issue but In my application external loader option is not showing , how to resolve this issue .
2025-07-22 3:24 AM
The appearance is changed. It is now on top of Misc
