QUADSPI examples using OCTOSPI peripheral
‎2023-05-09 12:12 PM
Is there any example of how to interface a NOR FLASH QUADSPI memory using the OCTOSPI interface used in the H72x, U5 or H5?
- Labels:
OctoSPI
QSPI
STM32H7 Series
STM32U5 series
‎2023-05-10 12:20 AM
Hello @AMend.7​ ,
To configurate QUADSPI using OCTOSPI peripheral, I recommend you to take a look to AN5050 and precisely 6.2 OCTOSPI configuration with STM32CubeMX Section .
In the mentioned application note, you need to refer to the tables "STM32CubeMX - Configuration of OCTOSPI signals and mode" and look deeply to the provided examples.
I Hope this help you!
Kaouthar
‎2023-05-09 1:07 PM
I built an example on the NUCLEO-H723 if you're looking for a consult.​
Hello @AMend.7​ ,
Kaouthar
