QSPI_FLAG_SM timing out on QSPI flash test
MRex
Our board is using an STM32H753 MCU with QSPI Serial Flash IS25WQ040. Quad SPI was enabled in CubeMX and I see the QSPI functions in stm32h7xx_hal_qspi.c.
I'm just trying to get a Qspi_Test function called from main working that is currently getting stuck. Here is the code from HAL_QSPI_AutoPolling function:
  if(hqspi->State == HAL_QSPI_STATE_READY)
    hqspi->ErrorCode = HAL_QSPI_ERROR_NONE;
    /* Update state */
    hqspi->State = HAL_QSPI_STATE_BUSY_AUTO_POLLING;
    /* Wait till BUSY flag reset */
    status = QSPI_WaitFlagStateUntilTimeout(hqspi, QSPI_FLAG_BUSY, RESET, tickstart, Timeout);
    if (status == HAL_OK)
      /* Configure QSPI: PSMAR register with the status match value */
      WRITE_REG(hqspi->Instance->PSMAR, cfg->Match);
      /* Configure QSPI: PSMKR register with the status mask value */
      WRITE_REG(hqspi->Instance->PSMKR, cfg->Mask);
      /* Configure QSPI: PIR register with the interval value */
      WRITE_REG(hqspi->Instance->PIR, cfg->Interval);
      /* Configure QSPI: CR register with Match mode and Automatic stop enabled
      (otherwise there will be an infinite loop in blocking mode) */
      MODIFY_REG(hqspi->Instance->CR, (QUADSPI_CR_PMM | QUADSPI_CR_APMS),
               (cfg->MatchMode | QSPI_AUTOMATIC_STOP_ENABLE));
      /* Call the configuration function */
      cmd->NbData = cfg->StatusBytesSize;
      QSPI_Config(hqspi, cmd, QSPI_FUNCTIONAL_MODE_AUTO_POLLING);
      /* Wait until SM flag is set to go back in idle state */
      status = QSPI_WaitFlagStateUntilTimeout(hqspi, QSPI_FLAG_SM, SET, tickstart, Timeout);
        __HAL_QSPI_CLEAR_FLAG(hqspi, QSPI_FLAG_SM);
        /* Update state */
        hqspi->State = HAL_QSPI_STATE_READY;
The problem is the following line of code where the status is always 1 instead of 0:
I'm not sure what the original developer did in terms of adding/modifying after the CubeMX generation, so if there is a chunk of code expected to be added by user and not CubeMX, that is most likely what I'm missing.
Any chance there is a simple and obvious cause for never setting the SM flag? Is there a minimal example project that I compare against for what is missing?
7 REPLIES 7
MRex
I'm still stuck on getting QSPI flash initialization working. I don't know if this problem is a configuration issue or a process/order-of-operations issue. Any advice pointing where to look next is greatly appreciated.
The problem is that the HAL_QSPI_Autopolling function times out. The flash is a 4Mb IS25WQ040.
main.c calls  MX_QUADSPI_Init();. That appears to return successfully.
void MX_QUADSPI_Init(void)
  hqspi.Instance = QUADSPI;
  hqspi.Init.ClockPrescaler = 4;
  hqspi.Init.FifoThreshold = 4;
  hqspi.Init.SampleShifting = QSPI_SAMPLE_SHIFTING_NONE;
  hqspi.Init.FlashSize = 22; // 22|24|25 see above
  hqspi.Init.ChipSelectHighTime = QSPI_CS_HIGH_TIME_1_CYCLE;
  hqspi.Init.ClockMode = QSPI_CLOCK_MODE_0;
  hqspi.Init.FlashID = QSPI_FLASH_ID_1;
  hqspi.Init.DualFlash = QSPI_DUALFLASH_DISABLE;
  if (HAL_QSPI_Init(&hqspi) != HAL_OK)
    Error_Handler();
void HAL_QSPI_MspInit(QSPI_HandleTypeDef* qspiHandle)
  if(qspiHandle->Instance==QUADSPI)
  /* USER CODE BEGIN QUADSPI_MspInit 0 */
  /* USER CODE END QUADSPI_MspInit 0 */
    /* QUADSPI clock enable */
    __HAL_RCC_QSPI_CLK_ENABLE();
    __HAL_RCC_GPIOG_CLK_ENABLE();
    __HAL_RCC_GPIOF_CLK_ENABLE();
    __HAL_RCC_GPIOD_CLK_ENABLE();
    /**QUADSPI GPIO Configuration
    PG6     ------> QUADSPI_BK1_NCS
    PF7     ------> QUADSPI_BK1_IO2
    PF10     ------> QUADSPI_CLK
    PD13     ------> QUADSPI_BK1_IO3
    PD12     ------> QUADSPI_BK1_IO1
    PD11     ------> QUADSPI_BK1_IO0
    GPIO_InitStruct.Pin = WICED_QSPI_PIN_CS_Pin;
    GPIO_InitStruct.Alternate = GPIO_AF10_QUADSPI;
    HAL_GPIO_Init(WICED_QSPI_PIN_CS_GPIO_Port, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = WICED_QSPI_PIN_D2_Pin|WICED_QSPI_PIN_CLK_Pin;
    GPIO_InitStruct.Alternate = GPIO_AF9_QUADSPI;
    HAL_GPIO_Init(GPIOF, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = WICED_QSPI_PIN_D3_Pin|WICED_QSPI_PIN_D1_Pin|WICED_QSPI_PIN_D0_Pin;
    HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
    /* QUADSPI interrupt Init */
    HAL_NVIC_SetPriority(QUADSPI_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(QUADSPI_IRQn);
  /* USER CODE BEGIN QUADSPI_MspInit 1 */
  /* USER CODE END QUADSPI_MspInit 1 */
So then I call a function to test QSPI:
HAL_StatusTypeDef Qspi_Test(QSPI_HandleTypeDef *hqspi)
  QSPI_CommandTypeDef sCommand;
  uint32_t address = 0;
  uint16_t index;
  __IO uint8_t step = 0;
  sCommand.InstructionMode   = QSPI_INSTRUCTION_1_LINE;
  sCommand.AddressSize       = QSPI_ADDRESS_24_BITS;
  sCommand.AlternateByteMode = QSPI_ALTERNATE_BYTES_NONE;
  sCommand.DdrMode           = QSPI_DDR_MODE_DISABLE;
  sCommand.DdrHoldHalfCycle  = QSPI_DDR_HHC_ANALOG_DELAY;
  sCommand.SIOOMode          = QSPI_SIOO_INST_EVERY_CMD;
  while(1)
    switch(step)
      case 0:
        CmdCplt = 0;
        /* Initialize Reception buffer --------------------------------------- */
        for (index = 0; index < BUFFER_SIZE; index++)
          aRxBuffer[index] = 0;
        printf("QSPI Enable write operations before\r\n");
        /* Enable write operations ------------------------------------------- */
        QSPI_WriteEnable(hqspi);
        printf("QSPI Enable write operations finished\r\n");
        /* Erasing Sequence -------------------------------------------------- */
        sCommand.Instruction = SECTOR_ERASE_CMD;
        sCommand.AddressMode = QSPI_ADDRESS_1_LINE;
        sCommand.Address     = address;
        sCommand.DataMode    = QSPI_DATA_NONE;
        sCommand.DummyCycles = 0;
        if (HAL_QSPI_Command_IT(hqspi, &sCommand) != HAL_OK)
        	printf("case0: HAL_QSPI_Command_IT Error_Handler\r\n");
        	Error_Handler();
        step++;
        break;
      case 1:
        if(CmdCplt != 0)
          CmdCplt = 0;
          StatusMatch = 0;
          /* Configure automatic polling mode to wait for end of erase ------- */
          QSPI_AutoPollingMemReady(hqspi);
          step++;
        break;
      case 2:
        if(StatusMatch != 0)
          StatusMatch = 0;
          TxCplt = 0;
          /* Enable write operations ----------------------------------------- */
          /* Writing Sequence ------------------------------------------------ */
          sCommand.Instruction = QUAD_IN_FAST_PROG_CMD;
          sCommand.DataMode    = QSPI_DATA_4_LINES;
          sCommand.NbData      = BUFFER_SIZE;
          if (HAL_QSPI_Command(hqspi, &sCommand, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
        	  printf("case2: HAL_QSPI_Command Error_Handler\r\n");
        	  Error_Handler();
          if (HAL_QSPI_Transmit_IT(hqspi, (uint8_t*)aTxBuffer) != HAL_OK)
        	  printf("case2: HAL_QSPI_Transmit_IT Error_Handler\r\n");
        	  Error_Handler();
          step++;
        break;
      case 3:
        if(TxCplt != 0)
          TxCplt = 0;
          StatusMatch = 0;
          /* Configure automatic polling mode to wait for end of program ----- */
          step++;
        break;
      case 4:
          StatusMatch = 0;
          RxCplt = 0;
          /* Configure Volatile Configuration register (with new dummy cycles) */
          QSPI_DummyCyclesCfg(hqspi);
          /* Reading Sequence ------------------------------------------------ */
          sCommand.Instruction = QUAD_OUT_FAST_READ_CMD;
          sCommand.DummyCycles = DUMMY_CLOCK_CYCLES_READ_QUAD;
        	  printf("case4: HAL_QSPI_Command Error_Handler\r\n");
        	  Error_Handler();
          if (HAL_QSPI_Receive_IT(hqspi, (uint8_t*)aRxBuffer) != HAL_OK)
        	  printf("case4: HAL_QSPI_Receive_IT Error_Handler\r\n");
        	  Error_Handler();
          step++;
        break;
      case 5:
        if (RxCplt != 0)
          RxCplt = 0;
          /* Result comparison ----------------------------------------------- */
            if (aRxBuffer[index] != aTxBuffer[index])
            	printf("case5: Fail\r\n");
            	Fail();
          address += QSPI_PAGE_SIZE;
          if(address >= QSPI_END_ADDR)
            address = 0;
          step = 0;
        break;
      default :
    	  printf("default case: Error_Handler\r\n");
    	  Error_Handler();
And it doesn't return from case 0's "QSPI_WriteEnable(hqspi);" In that function, its timing out from HAL_QSPI_AutoPolling function.
void QSPI_WriteEnable(QSPI_HandleTypeDef *hqspi)
  QSPI_AutoPollingTypeDef sConfig;
  /* Enable write operations ------------------------------------------ */
  sCommand.Instruction       = WRITE_ENABLE_CMD;
  sCommand.AddressMode       = QSPI_ADDRESS_NONE;
	  printf("HAL_QSPI_Command: Error_Handler\r\n");
	  Error_Handler();
  /* Configure automatic polling mode to wait for write enabling ---- */
  sConfig.Match           = 0x02;
  sConfig.Mask            = 0x02;
  sConfig.MatchMode       = QSPI_MATCH_MODE_AND;
  sConfig.StatusBytesSize = 1;
  sConfig.Interval        = 0x10;
  sConfig.AutomaticStop   = QSPI_AUTOMATIC_STOP_ENABLE;
  sCommand.Instruction    = READ_STATUS_REG_CMD;
  sCommand.DataMode       = QSPI_DATA_1_LINE;
  //sCommand.DataMode       = QSPI_DATA_4_LINES;
  if (HAL_QSPI_AutoPolling(hqspi, &sCommand, &sConfig, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
	  printf("HAL_QSPI_AutoPolling: Error_Handler\r\n");
	  Error_Handler();
Any help or suggestions greatly appreciated.
MRex
Ok, now i'm really confused. Connected up my Saleae logic analyzer to the flash chip and two things immediately stand out to me:
  1. I don't see the CLK toggling. I don't know how the other signals are showing negative edges at the same time without a clock. I've checked my wire lead to the flash and looks well soldered... but the code seems to be calling the functions to enable the QSPI clock in the HAL_QSPI_MspInit, so clock should be running.
  2. IO2, which is active low Write Protect, goes low and stays low. So I can see how it is getting stuck in QSPI_WriteEnable(hspi). IO2 and IO3 both have 10K pull-ups externally connected to them.
Since MX_QUADSPI_Init runs without hitting the Error_Handler(), I'm expecting my QSPI clock to be running from that point. Is this an incorrect assumption?
MRex
If I change:
to
if (HAL_QSPI_Command(&hqspi, &sCommand, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
if (HAL_QSPI_AutoPolling(&hqspi, &sCommand, &sConfig, HAL_QPSI_TIMEOUT_DEFAULT_VALUE) != HAL_OK)
It doesn't wait 5 seconds to timeout, it fails sooner (HAL_QSPI_Command only fails when using &hqspi and not hqspi). And I really thought that was the problem. I'm pretty sure it needs the ampersand. Right?
bitlischieber
I just had a similar issue.
At last i discovered, that the defines for my QSPI pins where defined wrong in a header file.
PDChauhan
Hello All,
I am facing the same issue - HAL_QSPI_AutoPolling () fails with timeout error. I have checked QSPI pins as per schematic and found correct. Before, this HAL_QSPI_AutoPolling function, I have successfully read Status Register 2 and also Write Enable command does not return with any error. So, I think Pinwise, it is okay. I have increased timeout value to 10000 from default 5000; just to give some more time.
But still behavior has not changed !
Can we replace this with simple reading Status Register and check that required bit?
Any hint or guidance is appreciated. I am really stuck with this error?
Thanks and Regards
PDChauhan
My Error is resolved by replacing:
 s_command.SIOOMode         = QSPI_SIOO_INST_ONLY_FIRST_CMD;
with
 s_command.SIOOMode         = QSPI_SIOO_INST_EVERY_CMD;
for write enable command after which I called AutoPolling function.
Yes, the hardware provides for a great deal of flexibility in how you interact with it, the functions here supposedly provide an optimal way, but not the only way.
Some memory devices permit a continuous stream to be read from the same register, others might not, you'd need to check the datasheet for the specific parts involved.
