Problem with Keil uVision 4: ''Failure loading STLinkUSBDriver.dll''
Options
‎2011-04-05 2:30 AM
Posted on April 05, 2011 at 11:30
when i try using the STM32 Discovery board (STM32F100) with Keil uVision (V4.20.03.0, Target DLL: STLink\ST-LINKIII-KEIL.dll V1.5.6), when i try to debug or flash there always pops up this error:''Failure loading STLinkUSBDriver.dll''. This Dll exists in the path C:\Keil\ARM\STLink\, but it just does not want to work. Any help is appreciated. Wolfram
12 REPLIES 12
Options
‎2011-05-16 5:04 PM
Posted on May 17, 2011 at 02:04
HI Steahler,
Thanks for the smart solution.. Although it is a dirty one, working like a charm! Cheers, SamOptions
‎2011-05-26 8:03 AM
Posted on May 26, 2011 at 17:03
Hi
Ibtissem
, theST-LINK V2 driver did the trick, thanks!
WolframOptions
‎2011-09-10 7:45 AM
Posted on September 10, 2011 at 16:45
My solution of problem:
Uninstall from Windows STLINK V2 soft, bacause this new STM32 ST-LINK Utility did not connects to my VLDISCOVERY. I'am happy did not delete older file um0892.zip (downloaded before 2011 March 18). After installing this older ST-LINK software I was able to connect to my VLDISCOVERY. To be happy with Keil environment : rename C:\Keil\ARM\STLink\STLinkUSBDriver.dll to ''..too_new...'' and copy olderSTLinkUSBDriver
.dll (2008.09.24) to this directory from C:\Program Files\STMicroelectronics\STM32 ST-LINK Utility_old\ST-LINK Utility. You must be Windows Administrator group member to use ST-Link with Keil. This will not depend on language settings. Regards, Juozas Kimtys
- « Previous
- 1
- 2
- Next »
