problem in generating a complementary pwm in stm32 g474ret6 nucleo board
‎2024-06-12 12:55 AM
As, i am using stm32g474ret6 nucleo board, i try to generate a complimentary pwm signal with timer 1 (pin PA0 and PC13) it does generate properly it create a curve at the falling edge .now i change a variable and try to generate this wave of 200khz it becomes triangular wave.
But in Timer 8 it generates properly with no error.
Can anybody tell me why this happen only in timer1 ?
STM32G4 Series
‎2024-06-12 9:13 AM
Hello @Harsh_18,
How are you configuring dead time insertion when using TIM1?
Please share your TIM1 configuration and specify the variable you're changing!
‎2024-06-12 8:13 PM
I only change the value of arr and ccr and the dead time is fix in each and every case.
‎2024-06-13 2:32 AM
Hello @Harsh_18,
Both TIM1 and TIM8 are connected to the APB2 bus, are advanced timers and have very similar functionalities
So, I would suspect the output pinout configuration differences between TIM1 and TIM8, you can check that!
