printf function call causes hard fault
Pramod K.G.
Hi all,
I am working on a STM32F103VEtx MCU. In my firmware I have redirected the printf function to a UART for debugging purposes. When I start running the code, the printf function causes the hard fault handler to hit. Please see the call stack attached below
Thread #1 (Suspended : Signal : SIGINT:Interrupt)
   prvGetRegistersFromStack() at stm32f1xx_it.c:109 0x800441a
   <signal handler called>() at 0xfffffff9
   std() at 0x8007abe
   __sinit() at 0x8007b76
   printf() at 0x8006dac
   main() at main.c:130 0x800400c
It seems like  std() function call triggers the hard fault. Please help me to figure out and fix the issue.
Thanks in advance,
Pramod K. G.
10 REPLIES 10
The runtime library sources should be available where your toolchain (compiler etc) came from.
