Press and release button
‎2022-05-31 5:07 AM
I need help to implement a function for some buttons, that every time a button is pressed a CAN message will be sent and when the button is released the CAN message will be sent again.
It has to send a CAN message for falling and rising edge (doesn't matter the time between falling and rising time), and I don't want to configure GPIO as GPIO_EXTI.
Thank you.
- Labels:
CAN
‎2022-05-31 7:07 AM
What I mean is something like the following code (GPIO-PinState can also be replaced by uint_32):
GPIO_PinState ButtonStateCurrent;
GPIO_PinState ButtonStateLast = GPIO_PIN_RESET;
while (1)
ButtonStateCurrent = HAL_GPIO_ReadPin(GPIO_Port, GPIO_Pin);
if (ButtonStateCurrent != ButtonStateLast)
Send_CAN_Msg();
ButtonStateLast = ButtonStateCurrent;
// any delay
BTW: the code will be better readable if you use the button Code Snippet = </> below.
‎2022-05-31 5:34 AM
Well, if you do not want to configure GPIO as GPIO_EXTI, i.e. you do not want to work with interrupt, you have to work in polling mode:
- declare pin status as a variable and set it to the start state (e.g. not pressed = 0),
- query the pin status in a simple while loop (e.g. via HAL_GPIO_ReadPin) and compare it with the variable mentioned before,
- if changed, store the status in the variable and send the CAN message
Does it answer your question?
/Peter
‎2022-05-31 6:38 AM
Thank you @Peter BENSCH​
Would you please complete the following code based on your suggestion.
BT1 = HAL_GPIO_ReadPin(GPIO_Port, GPIO_Pin);
if(BT1 == 0 && ...)
//Button is pressed
Send CAN; //send CAN only once
if(BT1 == 1 && ...)
Button is released
Thank you
‎2022-05-31 7:07 AM
while (1)
Send_CAN_Msg();
// any delay
‎2022-05-31 7:12 AM
Thank you so much @Peter BENSCH​
‎2022-05-31 7:17 AM
Would you please look at this question and if you could answer it, @Peter BENSCH​
https://community.st.com/s/question/0D53W00001aIZKRSA4/both-can-bus-interrupt
Thank you.
‎2022-05-31 8:15 AM
If this question cannot be answered by anyone here in the community, you should perhaps make a personal enquiry in our Online Support so that you can be helped directly.
/Peter
