NUCLEO-L452RE: ADC with DMA: Problems with more than 5 channels
MMuel.1861
If I use
HAL_ADC_Start_DMA(&hadc1, (uint32_t*)uiAdcResults, ADC_NUMBER_OF_CHANNELS);
it only works with up to 5 channels. With more channels there are problems with some channels in the DAM result array. For example with 7 channels, only channel 2...5 are OK. Values of channel 1, 6 und 7 are not OK at all.
I have no idea what the problem is. Cube parameters or source code can not be totally wrong because I tried it with 3...5 channels and this was OK, If I increase the number of channels (>5) the problem occurs.
4 REPLIES 4
What does "OK" and "not OK" mean, precisely? Did you try using max sampling time?
MMuel.1861
Not OK for example on channel 1:
Value in watch window it is always about 470 (460...480), even if there ist GND or 3,3V on the port pin. It seems that a totally wrong register is copied to the array.
I also tried now with maximum sampling time (640.5 Cycles). No change.
MMuel.1861
I attached the copmplete project. I have used an old Cube (version 4.23.0). But I do not think that this is the problem.
I use Segger compiler V4.30C.
MMuel.1861
and here the watch window with remarks.
Strange, because I also tried with 3...5 channels. All was OK then, also channel 1 (Array 0).
