No Space in execution region with .ANY
‎2019-01-23 1:59 AM
I am working for an project with STM32L496 target board.
When i tried building the project, i got the error saying,
ERROR: L6406E : No Space in execution region with .ANY main.o(.bss).
I am trying to use full SRAM memory present(320KB) for the global and stack variables. Load and execution is done from the Flash(1MB).
How can i access/use total SRAM available memory for my project..?
Please help me.
STM32L4 Series
‎2019-01-23 2:37 AM
This error is caused by some setting in your linker script and usage for RAM/Flash in your program. As you don't give any information about the used linker scripts, the particularities of your program, the projects and your compiler, we ca not help you.
‎2019-01-23 3:16 AM
Make sure all memory is described to linker, if the areas are non-contiguous you'll need to use pragma or attribute setting to direct usage. ​
‎2019-01-23 8:26 PM
Hi Clive Two.Zero
Thanks for your fast reply.
Please can you elaborate what to do.As i am Newbie unable to understand.
‎2019-01-23 8:35 PM
Hi Uwe Bonnes,
Thanks for your quikr reply, and here i am attaching my linker and memory usage options for you. Please find them and suggest me further.
Thanks.
‎2019-01-23 8:35 PM
‎2019-01-23 10:50 PM
Somehow i have managed to solve that issue by modifying the scatter file(just increased the RW and ZI sections frmo Flash).
First, Disabled -> Use Memory Layout form Target Dialog option (So that i can use my own Scatter file). To disable goto, Option for Target -> Linker , and diasbled.
Second, modified orginal Scatter file. Drawn some memory from FLASH memory which is 1MB of size and made it to RW section.Can look into the image i have attached for more details of scatter file.
Added this lines to scatter file,
RW_IROM1 0x080CE000 0x32000 {
.ANY (+RW +ZI)
But, can i use Flash memory for RW & ZI purpose, is that okay to use.
